Temperature compensated MAIDA
I've noticed that my Maida regulators drift with temperature -- LB47 has a compensated circuit using the LM329 -- here's how to implement -- first the schematic:
Here's a single layer version free for the pickin'
wirewiggler said:
Jack,
Can you send me the file on this, I will try to make one by hand.
Bill
PM me your email address. I changed the voltage setting resistor to consist of 2 units -- it's less expensive to use a pair of 3W devices and spread the heat.
okapi said:
Hi Jack,
can i ask what you need the high voltage for?
thanks.
Tube preamp.
okapi said:
this is the data sheet for the Maida regulator from national (1980).
The Value of C1 should be 1uF, not 100F -- this is a recurrent problem with Multisim -- but when I translated Multisim to Ultiboard I changed the value to 100nF -- should be 1uF -- thank for pointing out the error. A 1uF pp also has a bigger footprint.
The pass transistors which Maida used are now unobtanium. The TIP50's are rated 500V and are more than sufficient for the task.
diyAudio Chief Moderator
Joined 2002
I just use a single IRF840 pass element.
unfortunately, i can't take any credit for finding an error. I was just posting the application note so that beginners like myself, who can't figure out a circuit without an explanation, could make also make use of your helpful post.
i believe you have also built the jung super reg, how does the noise level of the Maida with the lm329 compare?
Janneman, I believe, did the definitive work on the Jung super-reg. I use a smt version of the Jung/Didden in my rework of the Crown IC-150 with wonderful results.
Somewhere in the universe of diyaudio is a comparison of the Last-PAS regulator and my LR8N3 (supertex) regulator. I used a storage-scope, bandwidth limited, to integrate noise over time. I haven't put the temp compensated Maida through these paces.
The LastPAS can be a little wonky with respect to temperature and I found that the current range of HV zeners are more prone to failure than their Pb cousins.
The LastPas is a really quiet, really low impedance supply.
Jack, have you run these boards yet?
I cannot seem to find any 1uF PP that will fit. For example, Wima MKP4 has a 1uF/630V that has a LS of 27.5mm. Even if you switch to polyester, MKS 4 in the same voltage rating, 27.5mm is the best you can do.
Also, on the 5W R6, can you slightly enlarge that footprint, to either fit a 24mm body resistor (for example, Kiwame 5W) or preferably the 12W Mills MRA12 non-inductive, which body measures 1.188" +/- 0.062" in length by 0.312" +/- 0.031" in diameter. The leads measure 1.500" in length minimum by 0.040" in diameter.
I think you'll have to make the board a bit larger to accommodate these larger devices.
wirewiggler said:
Darn 2 sided, this was going to be my first attempt at photo etching a board.
May just have to make with proto board.
Just burn the top-side and hard-wire the bottom.
I purposefully put the radial component connections on the bottom copper so that they could be hard-wired. With the new CNC PCB Mill I will have to figure out how to plate through-holes, but in the absence of such knowledge radial components will be connected this way.
