TECHNICS ST GT650 TUNER Mod
Joined 2006
Yes, that should do the trick (at least I can't think of any reason why it wouldn't). Maybe it is a good idea to disconnect the electrolytic capacitor at the base of Q701 (C707?) to make the relay switch faster and reduce contact wear. You won't need a diode for clamping the voltage at switch-off, as this is already taken care of by the zener (in forward conduction mode) and Q701.
Thank you again Marcel
I will post here my results :)
Joined 2006
Lifting Q701 emitter and feeding there the shunt output was a disaster... Loads of distortion and the tuner started to pick up sveveral stations at the same time (superimposed).
After looking carefully to the schematic I see the TX (10Vac) is connected to C705 C706 as to form a voltage doubler... Maybe lifting Q701 emitter causes some instability.
So I powered the AN6554 output quad opamp directly from the shunt and got a nice improvement in spatiality and detail presentation.... pics will be here soon :)
Joined 2006
Pics
Next I will verify if the onboard +14v is enough to power a relay to switch the external psu on/off.
I also replaced the output caps (3.3u 50v by 47u cerafines) and the onboard psu caps to 2200u Pana FC.
After some hours burning in I am pleased with the result... wider sounstage, better detail, "bigger" presentation.
This is all just for fun because this player is very limited.... it can not be compared with a high end machine off course.
Maybe I will replace the output quad opamp by a LME49740.... That might be a good improvement.
I own a GT550 ( GT650 but without LW ) and i am having reception issues. I saw a few months ago a thread on another site ( that got removed in the mean time ) of a front end upgrade on such a unit. Does anyone here have enough FM tuner experience to recommend an easy replaceable frontend for this tuner ?
Another problem i am having is with L301 adjustable filter that needs readjustment about every 6 months.
Joined 2006
Some more pics of the tuner.
I used the inboard 14v psu line to power a relay that switches the BiB PSU using the tuner´s standby button.
Works perfectly.
Powering the output quad opamp with a dedicated shunt psu proved worthwhile.
