Technics SL-1200 DC Power Supply
I presume this is voltage directly from your power supply. What kind of voltage are you getting at the on-deck regulator? Since you have moved the PSU outboard, I presume you've removed the bridge rectifier from the PCB. Where have you attached your new PSU to the deck?
Also, DO NOT hit the start/stop button without the platter installed - this will cause damage to the circuitry.
