I've done a quick search bit I cant find any problem similar to mine.
Basically I swapped the tone arm for the origin live arm board and RB300, the deck was fine before I started but when I put it all back together it wont start. It powers up and all the lights work but when I press start the platter doesnt move, I cant hear any noise either so its not even trying to spin.
I dont understand what I've done because I havent touched the electrics at all, just swapped over the arm board and arm, I did have to turn it upside down for a moment when I could get to a couple of screws, could this of done anything? also what happens if you try and start it up with the platter removed?
Thanks for any help
Thanks for any help
Yes I've downloaded the service manual, doesnt really help though as I dont know where to start looking for the problem!!
The only reason I mentioned about trying to start it with the platter removed is because someone else asked me this but they havent got back to me as why it matters.
Any suggestions on what the problem might be? I thought it might be a problem between the start/stop button and the main PCB but theres continuity between all the wires at both ends.
Looking at the trouble shooting part of the manual, the most common problem with a dead motor is Q1-Q3 being faulty, apart from a bad fuse.
Check the voltages at these points. Also, Q201 and surrounding components tend to have bad solder joints.
Is your SL1210 an old or a newer model?
You can easily know from the nasty busses in the bottom plate. The new version doesn't have them anymore.
/Hugo
/Hugo
Netlist said:Looking at the trouble shooting part of the manual, the most common problem with a dead motor is Q1-Q3 being faulty, apart from a bad fuse.
/Hugo
I'll have a look at what you mentioned.
whats a "nasty busses" ? its a mk5 if that helps.
