Te7022 Ebay board+PCM5102+Alps RK27
Layout almost done.
Will need to make some sort of adaptor to make the TE7022 board fit, but should be an easy task.
Kept all tracks on the top layer except at the USB isolator, which due to easier layout was put on the bottom, otherwise the bottom GND layer is 100% unbroken.
Vias from all capacitor/resistor GND to the bottom GND plane as well as from all the IC GND pins.
