Hi all,
I got some spare parts from old speakers and I wanted to make them into one large active box but need help with the wiring. I’ve been searching for a while and trying to learn how crossovers work with impedance but can’t get my head around it all.
Part list:
4Woofers:
2x Walferdale (100w/50w rms) - multimeter reads 3.4 (on the back it says 4-8ohms)
2x JPW (70w/rms not sure) - multimeter reads 4.9 (on the back it says 6 ohms)
3Tweeters:
1 x Walferdale multimeter reads 5.8 ohms
2 x Unknown dome 4inch – multimeter reads 5.8 ohms
Power:
1 x SMPS 360w (36v 10A)
Amp
1 x TDA7498E 160W+160W
Crossover
2 x 400w stable Treble/Bass Frequency Divider
So I need some help working out the wiring, I’m not sure the best way to go…
Plan A - amp as stereo going into two crossovers L+R then speakers (confused on the ohms and layout of wires for the speakers) - Data sheet says 4ohm 125w @1% stereo
Plan B - amp as mono going into one crossovers then speakers (again confused on the ohms and layout of wires for the speakers) - Data sheet says 3ohm 170w @1% mono
Im trying to maximise the power but I’m not sure how the crossovers interact with the ohms and what the TDA7498E can handle I saw a video on youtube showing the amp being tested at 2.67ohms which gave out 150RMS but I don’t know if the TDA7498E can handle it for long periods..
Any help would be amazing.
Part list:
4Woofers:
3Tweeters:
Power:
Amp
Crossover
