TDA1543 DAC with resistor I/V and tube amp
I modified my old Magnavox CDB600 (really a Philips machine) CD player. It uses a TDA1543 "twin DAC" DAC chip, and it used to feed op-amp I/V converter circuits. But I found that this DAC chip seems quite happy to feed a resistive load for the I/V circuit. This DAC chip has, for each channel, a constant source current generator, and a varying (to the music) a sink current generator. The difference current between these two goes into/from the resistor load. It wants a bias of about 2.2V for this resistor load (going directly to ground with the resistor doesn't work, sounds awful like severe clipping). This 2.2V bias needs to source or sink current. A conventional voltage regulator chip would only source current but not sink current, so that won't work. But an easy way to create this is to use a voltage divider network, 3k resistor from +5V, 2.4K to ground, to create a thevanin equivalent of a 1.3k resistor going to 2.2V. The DAC develops something like 1Vp-p of audio, which feeds a cathode follower triode grid. I used existing power supply voltages inside this machine to get about 40V for this tube (not a lot, but it seems happy).
I used the light bulb symbol to indicate vacuum tube usage... :D
Joined 2003
Just a few comments:
1. The tda1543 is so popular, because it works fine at a supply voltage 8-9 Volts, allowing an almost 2 Volt RMS output. Therefore no need for an extra TUBE stage .....
2. From your design jpg it is unclear what supply voltage you use for the tda1543. If this is also 5 volt, this will most likely explain the distortion, as you clip the music signal.....
3. An extra tube stage "amplifying" the signal to 0.7 Volt seems useless in regard to point 1.
4. If you want to know about biasing properly a tda1543 and loading it with a resistor correctly you can do a few things:
a) search the DIY as suggested before :rolleyes:
b) read my detailed articles on this subject on my website
best regards
doede
Okay, should have mentioned it 5V.
Well, I'm a tube head.... :D
Well now I got it to work well, it must not be incorrect :D Seriously, I wanted to maintain the average voltage bias the TDA1543 saw with the op-amp circuir, so operating it into a resistor equivalent into a voltage similar to Vref seemed a sensable thing to do. Looked at your web site and your TDA1543 circuit and I do see a resistor going only to ground. You must have set your Ibias to be larger than the max the Idac ever sinks. And the current Ibias - Idac goes into your resistor. As long as Ibias is high enough to keep Idac operating corrrectly (voltage higher than something like 0.6V?) that should work. A concern I had was that the Idac circuit might not work quite right if the output voltage got too close to ground. The clipping I experienced before I did my above circuit must have been do to insufficient Ibias on Idac peaks. My use of the 2.2V equivalent source avoids that. It allows Idac to exceed Ibias.
Been there. Unless I missed it, there's no mention what Ibias does or what happens if it's misadjusted. Using several DAC chips in parallel is interesting though. But I'm not convinced that oversampling is bad. There's more than one right answer to many questions...
best regards
doede
