Bernhard said:Hi,
is it compatible ? Use 1 x 1541 instead 2 x PCM56 ?
Bernhard
Read the datasheets.
Re: Re: TDA1541 simultaneous mode compatible to PCM56 format
THANKS.
THANKS.
Re: Re: Re: TDA1541 simultaneous mode compatible to PCM56 format
I detect an ever so slight hint of hostility in that reply.Fair enough.
Rant on
In order attain a reasonable level of competence in any arena, one has to be prepared to put in some degree of effort, however basic. And what can be more basic than reading the datasheets?. I am frequently amazed by the kind of information people expect to be handed to them on a plate, while they at the same time are not prepared to put in the slightest effort.
Rant off
FWIW page 4 of the TDA1541A datasheet states clearly under the heading Input data selection that the data must Offset Binary when the TDA1541A is in simultaneous mode. BTW this topic was covered in detail in the thread covering rah's circuit for connecting to the TDA1541A in simultaneous mode.
Page 4 of the PCM56 datasheet under the heading Digital Input Codes states that the data for it is Binary Two's Complement.
Incompatible without glue logic I'd say, wouldn't you?
Bernhard said:
THANKS.
Rant on
Rant off
Re: Re: Re: Re: TDA1541 simultaneous mode compatible to PCM56 format
Sorry, I overread that.
The timing diagrams looked so nicely the same.
My idea was to put TDA1541 in a Technics player where PCM56 work back to back on halfwaves which seems to be the same as what is done in colinear PCM1702.
It would be the unique oportunity to gain higher resolution with 1541 and avoid digital zero crossing distortion.
There must be that glue logic somewhere on my hard disc...
Re: Re: Re: Re: Re: TDA1541 simultaneous mode compatible to PCM56 format
If you read the PCM63 datasheet, it will become very apparent that it is not possible to ape the Colinear process with a pair of audio dacs.
