The output current is actually 0 to 4mA, i.e. DC shifted. So the highest allowable resistor is 25/4=6.25ohm.revintage said:Hi Oshifis,
To check I have understood this right: About 1541, 25/2=12,5ohm is the highest allowable resistor? Output with 6 ohm will be 6*2=12mV?
A parentesis: About the CD 2V out std I find this unnecessary as not even a poweramp needs this much. Wouldn´t 0dBu=0,775V be enough? Or why not the semiprostd 300mV/10k? If we go for 6ohm load and 0,5V out we then only need 40x gain.
The resulting voltage drop is 0 to 25mV, that is 12.5mV peak (8.84mV RMS) sitting on 12.5mV DC.
In order to get 2V RMS (2.83V peak) from 8.84mV RMS (12.5mV peak), one needs about 226x gain. Of course, for 0.775V you need 88x, and for 300mV you need only 34x voltage gain.
The DC component must be blocked or shifted.
What I am not sure about, how hard is the +/-25mV compliance limit. How does the distortion increase when it is exceeded? Is there a diode to the substrate inside, a base-emitter diode or what? Is the output current modulated somehow by the output voltage? Questions, that maybe the designers of the chip are able to answer. Or perhaps someone who has measured the distortion vs. load resistor characteristics.
Try replace 4ne by 4 x AD8599, Best op amp so far....
If you still want more you can check regulator/clock/output caps to like 22 uf and bypass...
If you still want more then discrete opamp/tube
There is no limit to what you can spend !!!!
Ok, seriously if you have a tda1541 made in 1987 it is worth it because they are as good as the new tda1541as2, just maybe a little wilder
Does Philips mention 25mV limit for the passive conversion in 1541? I am aware of such remark in the documentation of 1541A. Having said this, the question is whether I should lower my passive I/U resistor which is now 100Ohm. I know that people suggest something like 30Ohm, but I am not sure whether they refer to 1541 or 1541A.
Hi All. I am new here and fan of TDA 1541 like many here... I'd like to thank Icsaszar for this info:
In my Marantz CD56 I applied a simple low noise transistor based 2 mA current source to feed directly the output of DAC. In this way I could eliminate output decoupling capacitors. It just works, but I am looking for better sounding solution.
Regards Raf
This info is not given in any of TDA1541 datasheets. This 2 mA current generates about 4 Volts DC on output of the I/U op-amp converter (1,8kOhm x 4mA), therefore the output electrolyte caps can be correctly polarized. However that makes the next filter op-amp operating around 4 Volts DC instead of nice 'zero' (maybe it's good because allows to avoid some op-amp "around zero output" distortions?)The output of the TDA1541 is sinking 2mA at zero analog output. This current varies between 0 and 4mA from negative to positive analog output peak.
Regards Raf
- Digital Line Level
- TDA1541 and TDA1543 questions
