TDA 2006 amplifier
MARK -PLEASE ILLUSTRATE YOUR SUGGESTION --
PLEASE SEND ME A DIAGRAM -OF HOW TO WIRE UP THE 24 VOLT
BUT I AM NOT SHOWING U OR USING FIG 15
I AM USING THE VERY VERY FIRST CIRCUIT THAT APPEARS ON THE TDA2006 PDF
PLEASE ONLY REFER TO THAT "TYPICAL CIRCUIT " ---
HOW DOES THREAD 29 DRAWING FIT INTO THE CIRCUIT --3 TERMINALS --
PLUS U SAY 12V NEG GOES TO PINS 3 ???
AGAIN ---I DO NOT UNDERSTAND YOUR VERY BRIEF OUTLINE --YOUR TERMINOLGY IS DIFFICULT TO FOLLOW ---
BEST IS A SIMPLE DRAWING --PLEASE SEND ME A DRAWING OF WHAT IS IN YOUR HEAD --I KNOW YOU HAVE THE SOLUTION ---BUT I WILL BURN THAT CHIP --ONE WRONG CONNECTION --I HAVE NO IDEA HOW TO CONNECT YOUR 2 X12V BATTERIES
PINS 2 -TO 3
EXACTLY WHAT I SAW /REALISED HUMBERTO -
WELL SPOTTED ---IF YOU STUDY THAT RIDICULOUS CIRCUIT SCHEMATIC
IT LOOKS LIKE PIN 2 SHOULD CROSS OVER 3 -THERE IS NO CLEAR
JOINT DOT SHOWN --TOOK ME WEEKS TO FIGURE OUT -
THEY MUST BE JOINED ---JUST TRY SEPARATE THEM ---
NO SOUND --ALL DEAD --CONNECT THEM AGAIN -- ALL COMES BACK \
FULL POWER -- WEIRD ? YES --
THIS TYPE OF DRAWING SCHEMATIC IS UNACCEPTABLE --
YOU HAVE AGONISED LIKE I DID IS IT OR IS IT NOT JOINED??
WELL IT IS --SADLY ITS NOT THE SOURCE OF THE DISTORTION
MY FRIEND --HAS TO BE MARKS ASSERTION --TWO 12VOLT BATTERIES
!!!IN SERIES
BUT I AM FRIGHTENED TO CONNECT --WHAT GOES WHERE --NOT WILLING TO SACRIFICE ANOTHER 5 TH CHIP ---!:eek:
HUMBERTO ---I AM ONLY INTERESTED IN THE FIRST TDA SCHEMATIC --
IT HAS ZERO ---IE NO 2200 OUT PUT CAP ---LOOK AGAIN--
FIG 15 IDS DIFFERENT --HAS MANY MORE COMP ---INCLUDING THA 2200 MF CAP
BUT I AM NOT BUILDING THE 15 AND 17 CIRCUITS --JUST THE FIRST SIMPLE ONE
THAT ROARS LIKE A LION --STILL WAITING FOR A CLEVER FELLA TO BSEND ME HIS
SUCCESSFUL CIRCUIT ---!!--MANY SAY THIS AND THAT ---PROVE IT !!
Trying to attach picture
DC supply = battery
WOW --THANKS HUMBERTO --BUT WHAT ON EARTH IS GND COMMON FROM BATTERY ?----A 12 VOLT BATTERY HAS ONLY 2 TERMINALS ---? I SEE 3 DIFFERENT CONN POINTS ?
OK DO U MEAN USE 2X 6VOLT BATTERIES?--OR TWO X 12VOLT BATTERIES
WHERE ARE THE BATTERIES ?----HOW DO THEY CONNECT TOGETHER IN SERIES AS MARK TRIED TO EXPLAIN ? DO U TAKE OFF A ARBITRARY O" TERMINAL SOMEWHERE INBETWEEN THE 2 BATTERIES ? SURELY 24 VOLTS WILL COOK THGE TDA 2006 CHIP ?
IF I CUT THE LINK BETWEEN PINS 2 AND 3 ---I AGREE --THEY SHUD NOT BE JOINED
BUT WILL IT WORK ? NOW I AM MORE PERPLEXED --
GIVE ME A CLEARER CONNECTION ---I DO NOT UNDERSTAND WHY 3 CONNECTIONS -
FROM 2 BATTERIES --MUST BE 4 TERMINALS FROM 2 BATTERIES SURELY ?
OR 2 X 6VOLT --? OR 2X 12 VOLT ? ---
NOW I AM LOST ----HELP !
I NEED MORE ACCURATE DRAWING OF THE SINGLE OR TWIN BATTERY CONNECTIONS TO THAT CIRCUIT ---THOSE RED LINES LOOK SCARY
Don´t you realize that "carl winter" is a TROLL, a FAKE, pretends not to understand idiotically simple instructions and has been laughing at all of us for weeks?
Don´t waste more time repeating answers, everything he needs to know has been CLEARLY answered a lot ago.
Jeezus !!!!!!
50 answers !!!!
He must feel proud !!!
For those doubting this, just a few chosen quotes from this clown:
can someone clarify /define what THREAD means??
total new to this forum -
fail to see what a length of cotton has to do with questions /answers?
end this 3 month agony
not sure what is meant by split 12volt supply
I cannot understand your complicated IFAN system --I live in a area with bad /slow internet on an African mountain ---
<<< REALLY ? No kiddin !!!
Next time he´ll complain his unrelieable power source comes from an elephant dung powered generator ;)
that IRFANVIEW is COMPLEX NIGHTMARE terminology
only pc guru ,s understand ---what happened to simple English
language for novices ?
its just too advanced for my learning curve status ---(don't even know what a cookie is -- --!!)
Well, you know enough to ask about them. ;)
somebody help ! I live in the bush ----no doctrates in pc hieroglyphics anywhere near !
have made so many amps ---- eg--the
TDA 7294 I BUILT 5 YRS AGO ----140 WATT mono amp
worked wonderful --till I blew it on overdrive solos with a
Gibson les Paul humbucker
So you built split supply 5X as complex TDA7294 5 years ago but now have no clue about what a split supply is? UNBELIEVABLE.
see if u can spot the GREMLIN !
I think I already have ;) ... he uses the alias carl winter ;)
Well, if anybody wants to keep wasting time here with this TROLL, be my guest.
To each his own.
I´d just suggest not repeating what has alredy been told, clearly and many times.
so grateful Humberto ---Yourself and Mark are my saviour ---
you guys certainly know your craft ---
I am off to purchase another 12 volt battery ----will connect using your battery schematic --- 2 x12v batteries into a single TDA amp?
please explain why the TDA 2006 PDF ----says this amp uses 12 -15 volts MAX?
WHY not simply --say --- " use TWO 12VOLT BATTERIES IN 12 -0 - 12 config??
no mention of
still wary of the neg to pos bridge between the two 12volt batteries -you call it
GROUND ? GND ? -- surely ground is same as EARTH?----
SO -- 3 connections --3 takeoffs from 2 x12volt batteries ---
ok ---I,d better back off ---
too many critics having a go at my amateur attempts
they are all so damn clever --
such comments --are only delivered by arrogant morons--
got on this forum for help --
now I am called a clown /fake /troll--
--nice one !--
sorry I kept asking for expert advice ---so many ******** have
not provided a single circuit that works ---
--thanx anyway ----
I/m outta here ---this forum is not for beginners---only pompous
self centred cretins --
( no disrespect to Mark and Humberto ---many thanks for your genuine kindness
ignore those armchair critics ---they love to have a go from the safety of their pc
bloody negative lot --no wonder the world is in conflict !)
