this project is characterized by a high circulating current
especially in the differential input stage
in fact is a current mirror CFP
the next stage is characterized by a bootstrap titpico schema Jeff Rowland
Then the typical triplet EF emitter follower
if you like to use the simulator calculates the optimized values of 35V dual
The page cannot be found
The page you are looking for might have been removed, had its name changed, or is temporarily unavailable.
No it's not. Look again, you have drawn it incorrectly.
Crossover
I would like to do the speakers for amplifier 60W RMS / 8 ohm. I watched the speakers Woofer Beyma 8BR40/N - 50W RMS, 35 - 6000 Hz, 90 dB, 8 ohm and Tweeter Beyma T2030 - 15W RMS, 1,5 - 20KHz, 95 dB, 8 ohm with crossover Beyma V2 hifi, 300 W, freq 3 KHz, 8ohm.
I turn to you, because I'm not so sure that this is a good relationship and frequency of cutting 3 KHz correct
Would it be better if I would use stronger tweeter and would cut the freq to 4 or 5 KHz
Does anybody can help me with advice and calculation for crossover
Best regards
Best regards
Why are you asking about speaker crossovers in an amplifier forum?
Craig
Probably because I registered for the first time today and I'm still a beginner. Please help me.
Go to the forums list, Look up the group "Speakers"
There You will find "Multi-Way" as the forum where it would suit fine to post your question.
Start by clinking this link: http://www.diyaudio.com/forums/multi-way/
- tash ma hall amp
