After replacing all the tl072,tl712,Q1,Q2,Q5,R125,and R126.
know there is audio at the output transistors gate, but no audio output.
using the negative terminal as groung, the voltages at the output
transitors pins are as fallow, starting from the transistor closer to the
speaker terminal as transistor number 1, pin1 12v, pin2 156v, pin3 12v.
number 2 transistor is the same voltage as number1. transistors number 3 and 4
pin1 6v, pin2 12v, pin3 .0v. Am I using the right ground?
- General Interest
- Car Audio
- taramps ta2700
