Tannoy HPD 385 Crossover problem
Hi
I have a sound in my tweeter of HPD385 coming for sure from the crossover, cause if i lay the crossover on soft ground, no problem, but mounted on the enclosure a little kind of scratching sound comes, not always, but in some frequance range
do know how to help me, please
josef
Administrator
Joined 2007
Not sure I fully understand :) but I think you are saying the tweeter makes this sound when the crossover is attached back in the cabinet. And the sound comes "from the tweeter".
Could the tightening of the crossover be distorting the cabinet and consequently the distorting the tweeter frame. Try loosening the tweeter fixing screws to see if it helps isolate the problem.
Official Court Jester
Joined 2003
:clown:
yup - common problem of generic answers :rofl:
now seriously - due fact that HPD is coaxial speaker , there is no possibility that deformation in speaker baffle is causing funny noise from tweeter
OP needs to post pictures , so we can see what type of xover he is having , so we can proceed with analysis
here it is
Thanks for your quick answers
here some pictures
Joined 2003
caps are good , mostly
so - knowing that there is enough info - google for rejuvenation of Tannoy xovers , and you'll find how to disassemble switches ; whatever , it's simple enough and you'll figure by your self how to do that
disassemble them ( taking enough pics here all the time , so you'll have enough info for proper re-assembling) , clean all metal parts with acetone or medical petrol (benzin), let them dry , put some vaseline on contacts , re-assemble them , put back on pcb and solder
while you there , clean all solder joints ( either with vacuum pump or solder wick) - work one by one ,and solder again
if wire ends are looking dark and brittle - either replace wires , or just short them by 5-10mm , blank isolation and solder again
that will solve intermittent contact problems
thanks its working now
hello and thanks for your good advices
I solderd all points on the crossover new, I mean I went with my soldering iron to every point and reheated, so it was melting and if there was not enough solder I put on, now its working, no cracking or strange sound
thanks
josef
