hi all,
i know that this is the SS section and i was hoping somebody can help me.
i'm in a mess right now trying to make my first DC heaters for my 2A3.
i thought that the calculation will be something like AC volts x 1.44 - diode voltage drop = DC volts
so i started with a 3.3VAC transformer and 1N5402 in bridge configuration with 4,700uF cap. without load i get 3.6VDC and with load it drops to 1.6V. i tried using a real bridge and got the same result.
the 2A3 is rated for 2.5V @ 2A heaters.
what and where am i doing it wrong?
TIA
TIA
arnoldc said:hi tubedude,
the 3.3VAC is coming from a single transformer with multiple secondaries (this is one of them). it is rated at 3A. should this be higher?
thanks
I think that maybe the best solution, is to have a higher AC voltage (say 5 or 6 V AC) and after the filter electrolytic to put a dropping resistor and after this resistor another electrolytic.
That way you can achieve two goals:
-Changing the value of the resistor you can "fine tune" the final DC voltage.
-The resistor in conjunction with the last capacitor ,will make a RC filter, that will reduce the ripple noise ,even more.
