Doubling the cross-section area while maintaining the height, so width and depth change, got it.... You have to double the cross-section area, keeping the height and the vent the same. ...
Keeping the vent the same = ? I assume the length and height do not change, but does that also mean blocking the sides in to keep the vent the same internal width?
Hello,
this is my first post in this forum. I have built a transmissionline (the vifantastisch) with Peerless TC9FD. I am looking to convert them to the SAT version and adding a subwoofer. However I dont want to build a sealed or ported enclosure as I like the sound of the TL.
I was wondering if I could use the TABAQ 5" plans and add a woofer like Omnes Audio SW 6.01 As far as I understand The most important TSP is the QTS which is 0.44. This should be in line with W5-2143. Has somebody already tried this? Iam thinking to drive this with Mivoc AM 80. This amp should have a Boost at 35Hz, which should not give an unwanted Peak at the lower range?
My Idea is to use the the Vifa TC9FD is already have and build a the Vifantastisch SAT. http://www.hifi-forum.de/viewthread-267-246-6.html#275
Its a closed box to be placed at the wall with 330µF capacitor for high pass. It should be a simple build.
looks like it could reach 28Hz hump in a MLTL, a lull at your 35Hz which would be handled by the amp boost around that.
The TC9FD will distort quite a bit under 400Hz. I don't suggest to push it down that low.
Then, I would add in active XO to handle the delay between your Vifantastisch and the MLTL.
Hi, I had an order of PLS-P830987 to a new build but received a note from Soundimports.eu that it won't be in stock again, as the manufacturer decided to put a miniman order quantity of 2000 pieces.
Do anyone have a recommendation for replacement? Or another source in EU?
This might be on option if Germany is not too far away from you?Hi, I had an order of PLS-P830987 to a new build but received a note from Soundimports.eu that it won't be in stock again, as the manufacturer decided to put a miniman order quantity of 2000 pieces.
https://www.lautsprechershop.de/chassis/peerless_en.htm#ty-PLS-P830987
Thank You! It seems okay, but they do not have a stock of these.This might be on option if Germany is not too far away from you?
Thanks for the reminder.There are many other drivers that have been used since.
There's even a list of suitable drivers on page 1.
Unfortunately, it looks like stock is a problem all over, including Parts Express and DigiKey.Thank You! It seems okay, but they do not have a stock of these.
Don’t know about your currency or shipping costs to Hungary, but the funny thing is for me (in Africa) those drivers will cost much cheaper buying from Parts Express in the USA than from any of the European suppliers, and that includes shipping.
I only used the TG9, I built it when the original 4" bamboo TangBand was out of stock already. I use it with BSC filter and I like it very much. I sure will do a comparison when the Peerless PLS arrives, I plan to replace the TG9 until I finish the new box. This is why I ordered four pcs.
H
Not sure how it may help, but this driver is available from Tout Le Haut-Parleur Shop (TLHP in France) at a very attractive cost..😉
Hi,Hi, I had an order of PLS-P830987 to a new build but received a note from Soundimports.eu that it won't be in stock again, as the manufacturer decided to put a miniman order quantity of 2000 pieces.
- Full Range
- TABAQ TL for Tangband
