Symmetrical supply rails with a 2 wire transformer, is it possible?
try this:
I suppose that'll work...but you can do better with a true full-wave voltage doubler. You can even use a bridge rect. here, though half the diodes act in parallel (IIRC), so it's less effective. (This strategy is used in dual-voltage switching supplies, where a switch or jumper changes it from FWB to FWD mode. Yep, the primary circuits have 340VDC on them!)
Anywho - it's basically two half-wave rectifiers pointing in opposite directions. One end of the transformer feeds a 'CT' between the two main filter caps, the other end feeds diodes which pump the caps alternately. This is known as a full-wave doubler because the ripple output is 120Hz, due to the stacked nature of the circuit.
I'll grab a circuit in a second...
Tim
This is also a pssebillity, little bit easy'r
some minor points
- buffer elco's must be 2X bigger then normally
- diodes must be able to handle a lot of current
note, total output voltage is double then normally
Greetz Rudy ( dahm dots :mad: )
Bricolo, Circlotron
Definitely won't work. Transformer is s/c by upper bridge top left diode in series with lower bridge bottom right diode. Sorry to be a party pooper.
I apologise for this hasting post ! sorry Bricolo !
I will learn to use sim tools a bit (a lot of bits !) better and will improve my electrical understanding skill, before replying to other similar posts
