Surplus Voltage Solution
I recently completed a "Retro-Mod" project on a Magnavox console amp. The biggest issue was the high TX output. It was about 40V over spec. I think this is caused because the the load from the other console components was removed from the circut.
What is the best way to tame the TX output?
I have several more amps to rework and expect will have a similar problem with these.
Whe running the amp at the high voltage the sound stage was completely confused and hard to listen to.
Not necessairly, He could have pulled out a tuner section, phono section, etc to get down to a basic power amp.
Original schematic and changes you made would be nice to have.
What is your B+ (HT) circuit? Pi filter, CLC?, CRC? You can manipulate the output of the filter section by changing values of the input cap, output cap, and inductor or resistor. Lowering the input cap value would be my first step, followed by increasing (or adding) resistance between the first and second caps.
Model it in PSU designer.
PSUD2
Thank all of you for your responses. I hope you can read the attached. How can you share large files?
I got the amp only so the PTX that powered other components in the console is now just providing power to the amp section.
What I did to solve the problem is add a couple 180 Ohm R's between the Rectifier and the first cap in the PS. This seems to work. I got the B++ down to 157V.
After I made this change the sound stage problem went away. I'm guessing it was either the high voltage/heat or the bias node for the amplifier stage was all screwed up.
The added resistors are adding a little more heat under the chassis than I would like. The other concern is that adding the resistors will reduce performance.
I recently downloaded PSU II (Duncan's Amps). I haven't had a chance to work with it. When I looked at it the first thing that poped up was the load resistance. Can this be accurately calculated or is it better to get the amps at B++ while the amp is running?
Thanks again for your responses. Considering I'm new at this I can use all the help I can get.
Tom
  • Mag 8606.pdf
