Supravox RTF64 design options (long)
Greets!
You're welcome!
Hmm, the procedure I have is a bit more complex and requires more info such as the OPT's Kva along with its primary and secondary DCR, so can't do a comparison.
Anyway, I didn't reverse engineer the Singular, but ignoring any Qts rise from OPI (which will increase the pipe's Q (Qp)), the RTF wants to 'feel' a ~8.778 ft^3 Vb if tuned to Vp = Fs. Factor in the QPI and it jumps to ~12 ft^3! A nfb SE amp wants to 'feel' a flat impedance though, so net Vb falls a bit to ~7.325 ft^3, but Fp rises to 108.5 Hz for the former and 88.8 Hz/~8.3 ft^3 for the latter. As you shrink Vb for a given Vp, F3 rises just like any other vented alignment.
GM
Some Other Boxes
Hello !
First, Sorry for my poor English vocabulary
Some other ideas for Supravox :
http://www.audiofanatic.it/Diffusori/Tqwt215/TQWT215_1.html
http://www.yildiz.edu.tr/~ilkorur/speaker/supravox.htm
I've tested the supravox TQWT, this one with the front vent ; Quite nothing below 150hz !
Another idea in a sealed box, 42 liters, give a good response from 75hz ( my actual home system )
I'm working on a MLTL, around 92 liters, the preliminary tests seems to give the good way ....
R.C.
Scott....
But in this case isn't better into a baffle?
Something like this?
Scott's MLTL posted recently seems like the best compromise to me now WRT size and performance. I mean the footprint is more manageble compared to the Tannoy type BR a few pages back. I'm interested in the Non-Bicone so the dims would be a bit larger than what he posted due to higher Vas.
Hi Scott,
Got your email. I just replied! Thanks!:)
fred
I see that the measured T/S parameters from this site
http://www.yildiz.edu.tr/~ilkorur/speaker/supravox.txt
are much more different from these of the manufacturer. Has anybody else tried to measure them?
I haven't any experience with loydspeakers, could this kind of descrepancy between measured-published specs be typical?
Or in other words: should i take the published spes nicht for granded?
Thanks in advance
Konstantinos
Thanks in advance
Konstantinos
Greets!
Not me, and yes, it's too often typical, though the industry as a whole considers +/- 10% exceptable, which these meet.
Anyway, the top sim is a T/S max flat using published specs and the bottom one is the measured specs in the same cab. It has marginally better acoustic efficiency, but the trade-off is somewhat degraded transient response which can be improved back to 'stock' with a minor increase in damping, so the spec differences are no big deal IMO for all but the perfectionists among us. ;)
That said, it's not wise to assume that all driver published specs are within +/- 10% or that using them will be 'close enough' for max performance.
GM
