I'd like to get opinions from you guys... Is it okay to adjust the widerange driver position on the truncated pyramid suprabaffle if it is used with a 'helper' tweeter? The widerange driver is ~5" similar to the FE127E but has a limited hf response. So I plan to add helper dome tweeter ~1" on the same suprabaffle.. I mean the the main driver would not be equidistant anymore to the suprabaffle edges/corners... Example attached below: Driver on top while tweeter is just below it...
Thanks.
Thanks.
for iBIBk
BTW guys, the truncated pyramid suprabaffle would be for the iBIBk design...
I would still follow the driver height of the design (FE127E), but the truncated pyramid suprabaffle would be adjusted to accomodate the tweeter.. Would there be any sonic/baffle step penalties if the main driver is not exactly positioned in the center of the suprabaffle? The main driver is whizerrless and has practically the same T/S parameters as the FE127E. Thanks!
Aesthetically I like the look of the truncated pyramid better than the oval suprabaffle. I also plan to move the k-slot halves on the sides.
*moderator could move the posts above to the iBib-k thread if deemed more appropriate*
