Guys,
Since Miero released recently LIRC module for bbb (Thank you Miero) maybe it will be worth to try to control squeezelite player remotely (using LIRC)?
Currently there is a LIRC solution for RPI. It is fast and allows to control the most needed functions of squeezelite:
The readme file is at the bottom of website:
https://github.com/ralph-irving/tcz-lirc
As I understand we need:
- Power
- Play
- Pause
- Next Track
- Previous Track
- Volume Up
- Volume Down
- Lirc kernel module,
- Lirc software,
- IRda kernel module,
- confiruration files for selected remote control
- squeezelie with compiled IR support (The last, full *armv6hf.tar.gz version of squeezelite can be downloaded from current maintainer of squeezelite Ralph Irving site: https://www.mediafire.com/folder/lllwjg7xjl1by/linux
The same on my bbbWith "lirc_bbb gpio_in_pin=66" in etc/modules:
Code:root@botic:~# dmesg | grep lirc root@botic:~#
Thanks, Looks promising.The "IRda kernel module" in your list is included in the lirc-bbb kernel module.
I'll buy Infrared Receiver and will try to test.
Apple Remote Control looks good (although I don't like Apple Inc.)
What do you think?
1. Have whatever DIY fun you like!
2. Is there anything fundamentally preferable in an IR remote versus a wifi solution, which is already developed for LMS/squeeze platforms and can be implemented for a few $? ...so much more control and already done...
https://play.google.com/store/apps/details?id=de.cedata.android.squeezecommander&hl=en
iPeng, the Original Music Remote
francolargo: The IR remote can be more ergonomic and simpler to use than smartphone
True - it is not always convenient to navigate to the control screen. Also, an IR remote has great battery life while a smartphone sometimes needs charging at inconvenient times. I use an old retired phone that has no other purpose, and that improves the convenience because there is no need for access security or running a variety of apps. ...just media control...
Have fun with it!
Frank and Miero,
I have the similar observations as you regarding (old-school but cool) IR control due to its:
speed, simplicity, convenience for the casual operations.
When I want to select next track or make a pause I don't have to look (concentrate) on mobile device bright screen.
Strange: looks like GPIO pin 67 is selected
With 'lirc_bbb' only in the /etc/modules file I have got:Kaskade, bern: please retry lirc-bbb again. I've updated both sources and the precompiled module.
Code:
[ 4.003371] lirc_dev: IR Remote Control driver registered, major 245
[ 4.013349] lirc_bbb lirc_bbb.0: lirc_dev: driver lirc_bbb registered at minor = 0
[ 4.970950] lirc_bbb: auto-detected active low receiver on GPIO pin 66
[ 4.970975] lirc_bbb: transmitter on GPIO pin 67
root@botic:~#
If the little silver Apple IR remote had a specific 'mute' button or function, I'd definitely want to add it to the system. Muting something annoying is the best use for such a remote, IMHO.
I hope that there will be options to assign selected buttons to the selected functions.
Maybe this configuration file may be used:
https://gist.github.com/pda/8252117
Thank you! Input is now on GPIO 66.
I can't get the rest to work though
Is there an easy way to check if BBB is recieving IR-signals?
I have IR sensor connected and the following files located in /etc/lirc/
hardware.conf
Code:
# /etc/lirc/hardware.conf
# Arguments which will be used when launching lircd
LIRCD_ARGS="--uinput"
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD=false
#Don't start irexec, even if a good config file seems to exist.
#START_IREXEC=false
#Try to load appropriate kernel modules
LOAD_MODULES=true
# Run "lircd --driver=help" for a list of supported drivers.
DRIVER="default"
# usually /dev/lirc0 is the correct setting for systems using udev
DEVICE="/dev/lirc0"
MODULES="lirc_bbb"
# Default configuration files for your hardware if any
LIRCD_CONF=""
LIRCMD_CONF=""
lircd.conf:
Code:
begin remote
name Apple_A1294
bits 8
flags SPACE_ENC|CONST_LENGTH
eps 30
aeps 100
header 9140 4390
one 608 1618
zero 608 518
ptrail 610
repeat 9141 2157
pre_data_bits 16
pre_data 0x77E1
post_data_bits 8
post_data 0x79
gap 107219
toggle_bit_mask 0x0
begin codes
KEY_UP 0x50 # Was: UP
KEY_DOWN 0x30 # Was: DOWN
KEY_LEFT 0x90 # Was: LEFT
KEY_RIGHT 0x60 # Was: RIGHT
KEY_PLAY 0xFA # Was: PLAY
KEY_MENU 0xC0 # Was: MENU
KEY_OK 0x3A # Was: OK
end codes
end remote
.lircrc:
Code:
begin
remote = Apple_A1294
button = KEY_UP
prog = irexec
config = echo "VolUP"
repeat = 1
end
begin
button = KEY_DOWN
prog = irexec
config = echo "VolDOWN"
repeat = 1
end
begin
button = KEY_MENU
prog = irexec
config = echo "Switch"
end
You can use any button for the Mute. One just need to define the Mute action for it
...except I want to mute the es9018s while also using the AppleTV! Hmmm!
Hey Frank,Greetings James,
This is probably going to seem like a sketchy reply - sorry - but in practice ALSA can be fairly sketchy. Clearing things up could take us far away from Botic per se. So, depending on the following, I may suggest that we move to a thread in which ALSA is the topic.
Botic doesn't specify the output device. The applications that run under Botic typically do so. Some applications will not accept ALSA plugins as output devices, but can accept 'hardware' output addresses (the correct term escapes me at present) like 'hw:0,0'. Unfortunately, I have never gotten MPD (nor Ecasound) to accept anything other than such addresses that bypass ALSA's programming space. That is why in my own system I am using squeezelite, because it does permit output to ALSA plugs. If this limitation of MPD is a deal breaker, then I can't help. You mentioned configuring squeezelite for Roon. If squeezelite is part of the system about which you inquire, then chances for success are good.
ALSA can do that, no problem. If you want to proceed, let me know and we'll pick up the ALSA discussion here: http://www.diyaudio.com/forums/twisted-pear/277564-ladspa-filters-digital-crossovers-bbb.html
Looking at and copying working ALSA syntax is one of the most effective ways to get things functioning.
thanks for the reply, that's very helpful
It's actually already proven to work in MPD using this method. I was only following a guide here but got stuck at the final step of choosing the new output device in MPD.
What I actually want to do, as you correctly assumed, is to get this working with Squeezelite. I noted from having played around previously that if I don't specify an audio output in Squeezelite, it works just fine with the default Botic output. So I figured 'How do I change the default Alsa output on the Botic build' was a more generic question than 'how do a I specify a different alsa plug in Squeezelite'
I'll move my Alsa questions to your other thread and in the meantime, I'll install Volumio and try and get it working via MPD and Volumio to prove the concept works and is compatible with my hardware tweakings.
I assume that an Alsa plug like this is the simplest way to get Botic to output 2 channels of right-justified data, split for left and right for a dual-mono dac?
thanks,
James
Also... is there something simple I can do which will allow me to use a remote tool like mpdroid to control the botic mpd? it seems like the port is not open to accept connections from anything other than the localhost ympd client?
Or... is there a simple way I can update the ympd to be the latest version? As I believe that may allow me to select the audio output
thanks,
James
thanks,
James
- More Vendors...
- Twisted Pear
- Support for Botic Linux driver
