I took a look at the TAA articles, and decided that it was time to build something with transistors in the TO-5 outline. This Sulzer regulator has the LM317/337 pre-regulators and uses the D44H11/D45H11 external pass transistors instead of the slower TO-3 kit. Sulzer had tantalums all over the place, so I raided my store from a Jameco kit of a dozen years ago, plus some 47u/35V devices purchased on the web:
Tantulums are much smaller compared to the time at which this design was first conceived.
I was thinking about building the Sulzer regulator, using a slightly different implementation. The purpose of this is not to improve its performance, but suits my needs a bit better, in case it can be done.
(1) I plan to discard the input filter of 47R-47u and replace it with a capacitance multiplier, because I need less voltage drop at 200mA. I believe it would not harm anything.
(2) I would like to use a TO-220 pass transistor, in that case 2N3053 does not suit me. The reason for this being that drilling just one hole is preferable for me - again I state that I don't want to discard the existing transistor to improve performance or what. In that case, I thought D44H11 (used in Jung regulator) should be a good choice - do you agree, or find anything else more useful?
Maximum current should be 200mA DC load.
Does anyone have the issues of Audio Amateur including the Sulzer articles? Year 1980-1981 as I remember.
I contacted audioXpress and they don't have any copies - even electronic ones.
2/1980 and 1/1981
- Power Supplies
- Sulzer regulator
