suitable power supply for dozen opamps?
15 VOLT +/- REGULATED SUPPLY
Hello
greetings simple regulated supply used in studio series preamplifier
warm regards
andrew;)
cheers moo, this was buggin my head all night ...
.. never really mastered electronics at school, failed physics because of it, passed second time round though,
I read EL transformer is more suitable for low level applications such as this over toroid...
However do I still need to take any precautionary mesures to supress humming regarding distance?
Originally I was going to incoorporate all of this into a butter dish for simplicity but it looks like I'll need something slightly bigger...
Administrator
Joined 2007
Radiated hum from the tranny shouldn't be an issue unless you wrap wires round or against it. Just keep a few inches space between it and the PCB/signal wiring and it will fine.
Ahhh, a biscuit tin amplifier.. nearly :D
It might be worth splashing out on something more suitable. Again, CPC stock loads.
what does c-p-c achieve exactly? don't wan't to make it too complex unless it enhances performace....
I'm going to put it in larger tupper ware then, not too keen on metal box.
I remember reading a while ago somewhere, isolating commons is good practice?
On interconnects the external ring is common/gnd, they act as a common line between devices, (in my case amp to 3way and all connected units).
If I wire the common from the 3 boards together but NOT to the GND of the regulator, would this minimise noise?
essentially isolating grounds between devices, instead of them all being lumped together,
Administrator
Joined 2007
C-R-C. Its just the reservoir cap followed by a low value series resistor feeding into another "reservoir" cap. It attenuates the final ripple and noise by a small amount, but like everything, there is a downside, and that is that it reduces efficiency but for small signal stuff that's normally a non issue.
When thinking of grounding and wiring layouts you have to consider each conductor as being a resistance, that resistance spread equally along its length. That means thinking in terms of current flows and how any volt drops developed along that "resistance" may interact with other points on the circuit that tap into it.
Administrator
Joined 2007
Thats a good question and the answer depends on the circuitry (in particular the opamps used). Now FET opamps have essentially zero input bias current which means that there is no voltage developed across the FET's input resistor (the external resistor on the circuit). An opamp like a 5532 does have significant bias current and can develop a small bias current across the input resistor.
So what I would advise is to actually measure the voltage across the cap in use and fit the caps accordingly. That said, with a FET device the voltages should be essentially zero, as should any DC offsets.
Administrator
Joined 2007
That's it.
I would definitely recommend you power it up initially with a bulb tester in series with the primary (unless you are 100% confident all is connected correctly). For something as small as this a 5-15 watt night light type bulb would be more suitable than a 60 or 100watt.
Also, some regulators need a minimum current to be drawn so don't automatically assume there could be a problem if you test and measure say -18 volts or higher from the 7915. And remember the 78 and 79 regs have different pin outs.
flippin heck. why do they do that?
I wired up the 79 up wrong, I think i've fried it...
To confirm i've done this right, a few things
- Secondry legs on transformer - two in the middle, they should be joined together and I've connected common line to this - I don't see how this helps seeing as I don't have an earth plug connected to the transformer?
- I put a fuse between the outer two secondry legs, will this help protect anything? i tried a 250mA fuse but it blows upon power up... I have a 3amp in it now.
