As the title suggest, I'm looking for options and opinions on 8" Fullrange drivers. My maximum budget is $500 CDN. Less would be better of course! This driver will be used for my first fullrange rear loaded horn project. I need somthing that will have the ability to produce reasonable bottom end. As far as im aware, Solen and CSS are the only places to purchase these speakers, if others options are out there, im all ears. I would prefer to buy from a Canadian company however.
The two drivers ive been looking at are the Fostex 206EN and the Alpair 12P. But I'm open to just about anything that fits the bill.
Thank you,
Thank you,
Alpair 12P and FE206 will not go as low as Alpair 10.2 or even EL70.
If you have a small SE amp (tube or SS) then consider the 206 for its efficiency. The SE amp will help counter itss foward presentation.
If you have a larger amp the less efficient MAs become options. They are better balanced. A big horn will counter most of the advantages of the larger A12, and the A10.2 & EL70 do better (better DDR) in the mids and tops.
If you have less than a top notch amp, the Alpairs will telegraph any shortcomings, the EL70 is more tolerant.
What kind of amp do you have.
Personally i'd choose EL70eN (and i have good amps), and build Maeshowe -- actually we (Chris) already did.
Bob (CSS) can get pretty much anything available at PE or Madisound. Solen are good but often pricey by comparison. I can get anything from Madisound, but prefer to sell only modified drivers (they would still fit into your budget), but in a couple weeks i should be pulling a number of FE206 off the break-in bench and could probably spare a stock set. I have pretty much all the EL70s in North America
dave
dave
Consider the Alpair 10.2 instead. It is a 6" unit
Actually a nominal 5 1/4" driver. (Thanx for echoing me while i typed)
Note that in any of the big Woden horns, actual bass extention with any of the mentioned drivers is dominated by the horn and extention is broadly similar.
I have had Maeshowe (EL70eN and A7.3eN and proto Valiant (FE126eN^2)), and Victor (FE166eSR, FE166eN^2, and FE166eSReN) in my listening room.
dave
Some "dumb" questions listed below!
What is "BSC built in"?
"better DDR"?
I understand that cone area is not always king in regards to extension, but at a moderate listening level, can the EL70 really keep up with a speaker with basically twice the cone area? I'm more than happy to save money and get a better speaker (better is maybe not be best word), but my brain is having trouble absorbing this information.
My current amplifier for my stereo is a Pioneer SX 826 (70 watts per channel at 8ohms). This is a very old reciever, but seems to do a good job for me.
"better DDR"?
BSC = Baffle Step Compensation, built in means that the drivers have a bump up in response right where you need it.
"better DDR"?
Downward Dynamic Range. More crudely a lower noise floor and the ability to reproduce very low signals in the presence of larger ones. The characteristics that put flesh on a voice, tell you that it is this kind of violin instead of that kind, or how the guy is picking the guitar, and provides crtitcal information to improve imaging/soundstage
At moderate level, for sure.
Bernie (one of the master woodworker's i work with), converted his A12 (original metal) enclosures to EL70 because he preferred them, and prefers those to his Victor with FE166eSReN.
Given just that EL70 jumps to the top
dave
Is the Maeshowe design available here (on this site?)
You have to buy the plans from Woden
What do the modified EL70en speakers look like? still black?
And until such time as i need to start treating them you can get stock ones at the same price Bob was selling them, but IMO the matched & treated pairs are better value.
dave
Teeny drivers produce teeny sounds. Simple Physics.
but the smaller cones are more rigid so you get better midrange clarity. it's all tradeoffs. most people listen to music at 80 dB anyway, that's much less than one watt. if one desires high SPL party speaker, they are wasting their time here in the fullrange forum.
I told you you should have come over for diyFEST, then you'd know how wrong you are.
dave
- Full Range
- Suggestions on an 8" Fullrange needed
