The requirements are:
1. Frequency range___20-120Hz
2. SPL required____???(I'm roockie)
3. Mono or stereo_____ Stereo
4. Desired size and weight___ no problem about that
5. Cost_____ less then $1000
6. Location with respect to "main" speakers___any
7. Passive or active crossover____ACTIVE
Thanks,
Cristiano
Thanks,
Cristiano
You may want to check out the Shiva woofers at Avatar Audio. Their white paper is a good introduction and provides a lot of design options. I'd recommend, for a rookie, sticking with closed-box systems; tuning ported and PR systems without the use of good quality impedance measuring equipment and a firm handle on what you're doing is dicey at best.
And use built-in plate amps. For this frequency range, you don't need anything fancy, just lots of power and reasonably low distortion.
SY said:You may want to check out the Shiva woofers at Avatar Audio.
They now are called Adire Audio.
cristiano said:Hello,
I would like to star in a DIY project but I'm complete rockie. I need for my sistem a subwoofer. Could someone help me to find:
- wood work;
- and a DIY projects of a quality subwoofers.
Start here:
http://www.diysubwoofers.org/
Then there's:
http://www.linkwitzlab.com/thor-intro.htm
good luck
pf
- Subwoofers
- Subwoofer Help
