It appears that these are being used as ±15v regulators. Everything appears to be OK. They get hot because they're dissipating power from the voltage drop (26-15v) and the current flowing through them.
You should not have had the same reading on the emitter pads with the transistors out of the circuit.
I measured voltages on various transistors and have all negative voltages on 2sc1027. E=-38V, C=-0.4V, B=-35V. How come they all have the same polarity. Isn't the base of a NPN transistor driven by a positive voltage and the current being controlled flows from collector to emitter? Also, the the driver KD600K reads E=0.8V, B=36V, C=0.3V. Isn't emitter supposed to be negative? I'm sure that all the transistors are where they are supposed to be, since I wrote their location on a paper before removing or testing them. What would be worth checking next? Originally, the amp had two blown PS mosfets and one output driver. I think I'm going to remove all the diodes and test them one by one.
- General Interest
- Car Audio
- Subwoofer amplifier MIK
