Hi there,
I'm new to this list so I'll introduce myself first...
My name is Guy, I'm a computer programmer in Melbourne Australia.
I've recently got into subwoofer building and am about to start my first project. It's a home theater active sub, using a 12" peerless driver with 2 passive radiators. It will use a 240W RMS amp.
I've been using WinISD software to model the various properties of the sub and can see that the cone excursion of the driver gets too large when the frequency goes below 20Hz.
So I guess that I need a 24db per octave high pass filter at about 20Hz. My question is whether anyone on this list can suggest what I should do. Is there a good filter on the market I can buy, or is it easy enough to make one?
Any information would be greatly appreciated.
Guy
Guy
Guy,
Making a subsonic filter is very easy, especially if you go the kit route. Both DSE and Jaycar Electronics would have kits of Rob Evan's Subwoofer Processor (which only has a 6dB/oct subsonic filter if memory serves me well). Try Elliott Sound Products for more projects.
Cheers
Isaac
I'd give anything to get work like yours. It's hard being a fresh graduate
Cheers
Isaac
Thanks for the reply Isaac,
I sent an email to Elliott Sound Products (good web site btw) asking them if they had a high pass filter like the one I'm after.
Rod sent me a reply saying that he is going to design a 36dB/octave "phono rumble" high pass filter. This is exactly what I want, so I'll probably wait for this.
rumble
>>>>It's a home theater active sub, using a 12" peerless driver >>>>with 2 passive radiators. It will use a 240W RMS amp.
have u seen www.geocities.com/adrian_mack/index.html
>>I've been using WinISD software to model the various >>properties of the sub and can see that the cone excursion of >>the driver gets too large when the frequency goes below >>20Hz.
are u planning on playing LPs or 20hz test tones i wouldnt worry too much (or pipe organ music)
still good to have a subsonic filter though
i thought of getting a peerless XLS but i dont want to buy Passive radiators when pvc pipe will do,, perhaps a cerwin cega 12,,
or 18sound (15inch)
:-D
or 18sound (15inch)
:-D
This article from our moderator, Planet 10's site, shows how to put passive filters in line to the amplifier that feeds the subwoofer.
Looks useful for what you want.
http://www.t-linespeakers.org/tech/filters/passiveHLxo.html
guylemar,
Did Rod get back to you on that 36dB/oct filter? (likely availability etc...?)
I'd be interested as well.
Thanks,
David.
guylemar said:Hi there,
Guy
24db @ 20hz is about perfect for a subsonic filter for exactly the reason you stated. I generally like to use filters on in my builds. For HT they are a good idea as some movies have quite a lot of energy down low. For music a low cut filter will allow for maximum output from the sub without overload.
Whatever your source material, a low cut filter will optimize your subwoofers performance envelope.
You might want to try these as an interim solution while awaiting the real deal - they are good to have around anyway:
http://www.partsexpress.com/pe/show...7&St3=32021338&DS_ID=3&Product_ID=16209&DID=7
cheers!!!!
AudioFreak,
I know very little about passive xovers, let alone active ones. Would I be best off with a kit?
I'm guessing passive at that frequency is not an option due to size of inductors required?
Can you recommend a good book on xovers? (apart from Dickason's cookbook)?
thanks,
David.
thanks,
David.
Hmm... if it's a rumble filter you're going for, it's a high-pass filter, and those are usually done with capacitors...
though I too know very little about crossovers.
What I do know came from Radio Shack OP-AMP books (grin) and is pretty, um, rudimentary.
http://www.maxim-ic.com/appnotes.cfm/appnote_number/1795
That's a very good thing if you're going to do active crossing over... I haven't read the whole thing yet but it gets very in-depth. I suspect you could just pluck one of the designs out of there and modify values according to the equations given, and have an adequate filter for what you're going for.
- Subwoofers
- Subsonic filter for a SubWoofer
