Subkick modification
I have a speaker with the below specs that I currently use as a subkick microphone (speaker wired in reverse)
I would like to add a passive low pass filter and understand that I would probably need an inductor coil, my question though being an absolute electronic newbie, what kind of coil would I need and would this cause problems to the electronics of my sound card receiving this signal?
much appreciated legends.
Specification Sheet 165mm Polypropylene Bass Driver Description 165mm (6.5") speaker • Ideal for bookshelf hi-fi speakers • Polypropylene cone • Pressed steel basket Driver Parameters Electrical / Mechanical Voice coil resistance (Revc): ................................6.6 Ω
Impedance at Fo (Zo):........................................40.8 Ω
Resonant frequency (Fo): .................................48.4 Hz
Effective piston area (Sd): ..............................0.013 m2
Force factor (BL): .............................................6.23
TM Sensitivity (SPL): .............................87.5 dB @ 1W/1m
Acoustic volume (Vas):........................................20.7 L
Mechanical Q (Qms): .............................................3.36
Electrical Q (Qes):................................................0.648
Total Q (Qts):........................................................0.543
Compliance (Cms):...................................861.36 µm/N
Total moving mass (Mms): ...................................12.5g
Diaphragm mass (Mmd):......................................11.7g
Voice coil height (Hvc):......................................7.8 mm
Air gap height (Hag): ............................................4 mm
Maximum linear excursion (Xmax):...................1.9 mm
Motor Impedance Voice coil inductance @ 1kHz (Levc1): ...........1.03 mH
Voice coil inductance @ 20kHz (Levc2): .......0.474 mH
Resistance constant (Krm): ...........................0.776 mΩ
Reactance constant (Kxm): .............................10.1 mH
Resistance at 1kHz (Res1):................................2.26 Ω
Resistance at 20kHz (Res2):............................34.86 Ω
Resistance Exponent (Erm): ..............................0.9123
Reactance Exponent (Exm): ..............................0.7394
