Sub for 2x12" double horn technic
Hello,
i made a new construction for 12" bass driver,
small, easy to built, no bass resonance, lowest membran movement.
as a sideboard subwoofer or by using a coaxial driver as fullrange horn.
As PA multi it is useful up to ~200 Hz
Any opinion or questions
  • sideboard sub 30 cm funktion 1.pdf
Hm,
Looks like two different enclosures, have you measured the response of the actual cabinets, or is this just a plan?
Art
Why not if they're in parallel? They wouldn't get equal voltage in series, but parallel they would. The only problem with parallel is whether they add acoustically or not (in the band where they could). Different path lengths would normally require different delays - same reason you can't effectively mix horn and regular ported.
HM's designs utilize multiple horns with lengths calculated such that the fundamental peak and dip of one horn coincide somewhat with the fundamental dip and peak of the other. As far as delays go, there's some play room available in practice.
part list
Hi Members, owner, distributors, or producer of 12" driver,
next days i will publish the part list here in the forum,
publishing the plan on company website or DIY journals is
COPYRIGHT FREE with your driver. Production right need a licence.
driver which work:
oberton 12B400
kappa pro 12a
b+c12MH32
most driver with:
reso 30-70 Hz
Mms low as possible
B/l high as possible
EBP > 100 better 120
stroke as used, for HiFi in living rooms 3 mm would be enough.
also useful are coaxial driver or MHT horns between the enclosures,
the small one floorstanding the large with the coax, head a head on top.
MHT horns in sand filled single enclosures, with moving the enclosure
you can optimize the step response.
If there is no trust in the effect a cheap test for 3" driver plan here:
Hörner
it would be nice to publish the experience here in the forum.
