All my stuff that’s for sale combined in one list so it’s easy to keep track of.
IC
AD711an $2.00 ea (4)
AD712an $3.00 ea (3)
AD744an $3.00 ea (4)
AD797an $10.00 ea (4)
AD811an $3.00 ea (4)
MPC SM5813 DAC $8.00
OP176 $3.00
PCM56p DAC $8.00
SAA7210p Philips $5.00
SAA7220p Philips $5.00
SSM2141p Balanced to single end receiver $3.00
SSM2142p Single end to balanced line driver $3.00
TDA5709 Philips radial error signal processor $4.00
SS Parts
FETS
NTE 2382 Pwr Mosfet, 100V 10A $2.50ea (have 50, deals on multi over 10)
NTE2383 Pwr Mosfet, 100V 10A $3.50ea (have 50, deals on multi over 10)
MTM 12P10 $2.00 ea (5)
MTM 12N10 $2.00 ea (5) or $15.00 for all 8
2SK405 Real vintage 80’s Toshiba (4) $5.00 ea
2SJ115 Real vintage 80’s Toshiba (4) $5.00 ea or $30.00 for all 8
BJT
Power Tech MT1302AL NPN 100V 300A (500A peak), 400W @100c (650W @25c), hfe 40, matched pr. These Wholesale at $1200 pr, NEW sell $30.00 obo.
Phase Linear XPL909 (3), PL909 (2), SPD164 (2). $8.00 set
RCA 66546 (7703) (2) $2.00
Capacitors Oil/paper
GE Pyranol 50uf 330vac $5.00, 20uf 330Vac, $5.00
Captron Type III 27uf 700Vac (2) $8.00 ea
Philco 10uf 600Vdc $4.00
Sangamo 8uf 600Vdc $4.00
Sprague 8uf 1000Vdc $4.00
Pyramid 8uf 600Vdc NIB (3) $5.00 ea
Micamold 6uf 1000Vdc $4.00
Unmarked 6uf 600Vdc $4.00
Cornell-Dubilier 2uf 1000Vdc $3.00 Lot deal $40.00
Other
.012uf 1200v vintage Mica Large chassis mount postage stamp $2.00 ea (4)
.001uf 1200V vintage Mica Large chassis mount postage stamp $2.00 ea (4)
Grab bag of vintage postage stamp mica caps. 250V or better, 50 pieces $10.
Sprague Powerlytic 36D 2700uf 300Vdc $8.00ea, 4 for $20.00
Tube
Gates 833a for display, not working? No way to test $5.00
Raytheon Type BH globe. Stamped 1939. Cold cathode rectifier. Unable to test? $5.00
5963 untested but all good (purchased at ham fest from trusted seller) $1.00 ea set of 12 $8.00
XFMR
Edcore XSM15K/600 (5:1) 2.5W 20Hz to 20KHz <1 dBu, matching transformer. NEW, unused. $20.00 pr
Large DIY choke 28 awg coil wire, 4X3.5X2.5 open frame, varnish impreg, 12.5H, 200mA, 95 ohm (per B&K 875b LCR) heavy $20.00
HP/Paeco choke 6H, 125ma (2) $10.00 ea
Power Xfmr, T849-115A 800Vac CT 125ma, 6.3Vac, 5Vac $10.00
Allied 6K1VF 250Vct 25mA and 6.3V 1A NIB (designed for Bottlehead preamp) $15.00
Stancor P4089 6.3Vac 6 A $8.00
Stancor P4019 6.3Vac 3A $5.00
TT
AR spring set $5.00
10 mm X 12” boroscilicate glass tube (for linear tracking arm project) (3) $6.00 ea
3/8” CF tubing with attached headshell mount for uni-pivot arm project. $10.00
7” OAK dowel for tonearm $5.00
BluePoint needs stylus ($100.00 trade in value at Needle Doctor) $10.00
Uncut Aluminum/foam sandwich for arm boards, 6” X 6” $8.00
Moog Series C13 Samarium Cobalt DC Servo motor Model C13-L19W20M50. 12 VDC, 50 oz-in peak torque, 7.5 oz-in cont. stall torque, 19 oz-in running torque. Used but good condition $50.00
(see separate post for pictures and data sheet).
SPK
Adax DW50 Tweeters w/ angle mounts, 4 ohm, 94db. $25.00 pr
Mylar Done Tweeter, .75” 8ohm, 92db. Purchased from MCM p/n P11028 NIB $10.00pr
Blaupunkt P652C 2 way Co-ax. 6.5” 4 ohm, 91DB, 65 to 20Khz, 40w, NIB $20.00pr
4” paper cone 8ohm 3watt pr. $4.00
3” paper cone tweeter 8ohm 40watt $1.00
Other
Pioneer SX60 amp section, 30W/ch mounted on plywood (used a sub amp), works great, will remove from plywood to ship parts, w/ schematic. $25.00
Distech Silver Plus Interconnect, 3’ pr $20.00
DIY copper foil/Teflon 1” flat speaker cable, 6’ pr $25.00
DIY copper foil/Teflon ¼” flat intercoonect w/ gold ends 3’ pr $15.00
MIL-SPEC 29365 4RC2S06 wire, 24ga x 2 Silver plated Teflon insulation, 85% braid shield. 20’, $2.50’
Superphon
Superphon SA120 60W/ch amp bds. 15 raw bds w/schematic $2.00 ea
(used NTE 2382/2383 above, work in this design, plus I may have misc parts)
Superphon prototype phono stage using LT1122 ultra low noise IC and LT1010 buffer IC (from above) from Linear Techs app guide w/ ps (need xfmr, case, etc) 2 perf boards, w/schematic and artwork for finished design $25.00
Books/Lit/Man
Sound Pratices Mag set (15) all but Issue 4, 9 original, 6 Photocopy. $10.00
Radio Physics Course by Alfred Ghirardi, 1933 2nd ed. This has it all, tube, transformer theory $5.00
Original Audio Research D100 owner’s manual, with schematics, parts list. $2.00
Hafler Manuals $3.00 for set
DH-101 original owners/kit
DH-500 original owners/kit
XL-280 copy owners/kit
DH-200 schematic copy
9505 schematic copy
Musical Concepts Modification documents:
MKH-200, 220GX and TIP200 for DH-200
M500GX and GXB for DH-500
SuperMod IIIn and LIPS for DH-101
Thordarson Tru-Fidelity 1961 product catalog. Transformer specs, tube circuits. Photocopy, large $2.00
RCA Transmitting tube book. Photocopy, large $2.00
Wanted in trade
1N34a germanium diodes
One old style TRT Wonder Cap 3uf 425V
All small light weight items shipped free CONUS. All OBO.
IC
OP176 $3.00
PCM56p DAC $8.00
SS Parts
FETS
BJT
Other
Tube
XFMR
TT
AR spring set $5.00
SPK
Other
Superphon
Books/Lit/Man
9505 schematic copy
Wanted in trade
I would love to take them, those are new or used please let me know.
Picture would be nice.
Also interested on the HP/Paeco choke 6H, 125ma (2) $10.00 ea
Greetings Gabor
Greetings Gabor
