I have found these resistors on a Japanese PCB from a high tech monitor.
Never saw them before, does someone know their quality ?
They are non magnetic, have about 5% tolerance and where used in the video circuits extensively.
A picture of some of them, compared to a normal 1/4W resistor :
djmiddelkoop: Your devices look like Nikko-Ohm resistors to me. Probably the YQF series or something similar. The YQFs go for 40 yen per piece at Wakamatsu:
http://www.wakamatsu-net.com/cgibin/biz/page.cgi?cate=2012&page=0
View using Japanese font.
Similar plate-type resistors used to be made by Susumu, but they only make SMD components now.
http://www.susumu.co.jp/
hth, jonathan carr
hth, jonathan carr
Jonathan,
thanks for the information.
do these plate-type resistors have any special qualities like low inductance or noise ?
As they were used in high speed video circuitry and are non-magnetic I want to use them for my audio projects.
Do you recommend them ?
thanks,
Dick.
thanks,
Dick.
djmiddelkoop:
I haven't used the Nikkos all that extensively, so I shouldn't comment. I did use the Susumus off and on, and these were quite reasonable, I felt. These were touted as being both low-noise and low-inductance. Measured distortion was also somewhat lower than average for a metal-film. _If_ the Nikkos are similar to the Susumus, then there should be no problem with using them.
Not needing to form the leads makes life easier during the building process.
hth, jonathan carr
hth, jonathan carr
- Design & Build
- Parts
- Strange resistor
