Stacking a LOT of 3" speakers?
here are some pictures of the progress of my new project. the first one shows what I came home with from the wood shop.
I was really into that idea too, before I decided to go the "line array way" instead.
The problem that talked me out of it was the cancellations that will occur. I have no idea how serious this problem will be in practice , but theoretically it doesn't sound very good...
…What happens to the frequency response when you mount a LOT of small speakers tightly together…
You may find some useful answers here:
http://www.diyaudio.com/forums/showthread.php?postid=1215500#post1215500
Your short array is a small square and thus what is considered for the vertical dispersion will also apply for the horizontal, see the first picture.
Stacking several vertical line arrays made with point sources horizontally makes a plane source array to a certain extent, see the second picture where a T-line array is suggested as a complement.
The normal line array SPL/distance plot can be extended with a short ‘Close field’ region depending on the horizontal length (width) of the array where the SPL versus distance is constant(0 dB/ octave) and that extends to about the array-length/ 3.14 where the Nearfield (3 dB/ octave) takes over as can be seen in Jim Griffins papers: http://www.audiodiycentral.com/resource/pdf/nflawp.pdf
b
1(2)
