Stability of 2SK170 at small currents
Seems like those drawbacks doesn´t show up in this application, checked with a resistive network instead and no noticeable change.
The third 2SK170 is used as a CCS with 470k to ground. The CCS sets the output voltage through the gyrator whose gate has to be fed high-ohmic to function.
This one will output 30Vrms(B+=75V) into 10kohm with indications of well below 0.1% THD at a Zout of ca 500ohm.
