This amp is the biggest piece of junk ive ever worked on..
Ive removed all of the transistors from the driverboard..
If i put 1 A56 in the curcuit the amp will protect on me..
Any ideas on what to check since thats the only transistor in the curcuit and the amp protectss..?
Got the amp to power up..
The next problem i have is rail caps are rated for 80 volts..
The positive rail voltage is 94 volts
The negative rail voltage is 81 volts..
The 150K resistor measure 147.8 K out of the board..
Here are some pics of the board
- General Interest
- Car Audio
- SSL EV5000D
