One of the virtues of a battery powered system is no connections to Mother Earth.
Is Freax listening?
Battery supplies (or other low voltage high current situations) have rather different safety issues from normal mains. You won't get a shock from a low voltage battery, but you could spot-weld any metal which shorts it and get a nasty burn. I believe the usual advice is to remove all jewellery when near such a supply?
