Speakon sockets - how to fit?
I think Neutrik has the information that you seek right on their website. The cut out size varies depending on which jack you're using (4, 6 or 8 pole) but will be either D or G. I think they have dimensioned drawings in pdf for download.
Hope that helps.
Nate
P.s. I use #4 screws with D shaped housings, you might try M3.
Hope that helps.
Nate
Thanks Nate, how could I be so stupid as to not check their site! duh.
I was going to use the two pole ones, I will have a look thanks again.
Steve
Thanks Guys! I just wanted to use speakons because they look well made and secure.
Steve
Steve,
One more tip, there's a Greenlee punch that you can buy that is just about perfect for the D shaped openings. Makes life a lot easier, although it's not cheap at ~$40. If you do more than a couple it'll pay for itself in lost aggravation though. :)
Pretty sure that it's Part No: 730BB-15/16
Steve,
Thanks! I will check it out, never crossed my mind to use a punch rather than a drill. Maybe it would be easier.
Steve
