Hello,
I am going to build small speakers in my office for 5687 SE amp. So, the size I prefer is about Proac Tablette 50, and the sensitvity is about 88db/1m. Most of time I listen to jazz, vocal and chamber music. The diy projects I have considered are follows.
(1) Tony Gee's Hatt MKIII --- The sensitivity seems not sufficient?
(2) Tony Gee's Solo 103 --- His site no longer existed. I do not have the xover schemetics.
(3) Fostex 103 --- The standard bass reflex type enclosure version.
Any other suggestions? Anyone knows the difference between (2) and (3)? Thanks in advance for your input.
Dmigo
Dmigo
dmigo-
You might also consider the Dillon Ego... The design is available online free now. It has got a series filter, like the Gee designs. Hiquphon tweeter and Focal mid-woofer. His other design, the Metaphor, uses a Hiquphon tweeter and a Peerless mid-woofer, but might be a bit bigger than what you had in mind.
Ethan
Ethan
