Speaker Workshop question
I'd say you might want to doublecheck the cone area. It looks like this is data for a tweeter, and for a 1"/25mm tweeter, the Sd should be pi*2.5^2/4 = 4.9 cm^2
BL is probably not used in any calculations (you could put in 5 or 6 if you wanted to, just to see if anything happens - or doesn't happen when it is zero - it might use BL for excursion calcs...) , and Le would be very low, like .05mH or less...
BL can be calculated from rearranging:
Qes = 2*pi*Fs*Mms*Re/(BL^2) ...and the other potential unknowns in here can be figured out from T/S parameters, so it is really dumb on the programmer's part to ask the user to input it...
L1 and R1 are factors to help model nonlinear motor inductance, which is not an important issue for tweeters in most cases....leaving them zero will be fine. You would need measurements to determine L1 and R1 for the woofers (SW determines them automatically when you do a measurement and "calculate equivalence")
