Hello fellow DIYers, im wondering if someone could shed some light on a speaker protection circuit that is not engaging.
All output transistors have 8mv on the emitters so i have no shorts and it works if i mimic the final transistor to shunt half of the supply to the relay to ground.
The relay has +44v on each side, so im guessing once the final transistor has +0.6v on the base it will shunt one side to ground and enable the relay. However this transistor has 0v on the base, and im at a loss to what could be causing it.
Ive replaced all 4 diodes shown with new exact matches and also replaced the final 4 transistors (first 3 have 0V on the base, so these are not engaged). Voltages shown in the schematic are when the relay unlocks (half of what they are).
Any ideas?
Any ideas?
[/url]Toshiba SA-7100 Manual - AM/FM Stereo Receiver - HiFi Engine
Service manual is there, however it has a few errors, namely Q805 is a 2SA841.
If that is one of the bias setting diodes then you may well find damage to the output stage. Based on that I suspect your relay fault will be down to the emitter resistors being open and the 'current limiting detect' part of the relay driver coming into play thinking there is a massive overload.
- Speaker protection relay issue
