Greets!
I'm not set up to do it anymore so if I were to need it done I'd contact occasional poster Gordon Waters up in Marietta: http://www.diyaudio.com/forums/member.php?s=&action=getinfo&userid=38978
GM
GM
Thanks GM...
I'll try to get in touch with Gordon asap.
What I am up to is building a 90ish" line-array using 3 Gold Ribbon Concepts drivers and 8 per side 6.5" Peerless mid-woofs. If I can get Qt to .5 I should be able to eq to 20Hz in my small room, amp power allowing.
Best to you,
David
Best to you,
David
