: 5.25-inch (130mm) Midwoofer Loudspeakers
:: Max Power: 150 Watts
:: Continuous RMS Rating: 51 Watts
:: Recommended Amplifier Power: 5-51 Watts Per Channel RMS
:: Frequency Response: 70Hz ~ 2000Hz
:: Sensitivity: 91 dB/w*m (SPL)
:: Nominal Impedance: 4 Ohms
:: Maximum outside speaker diameter: 5.25" / 130mm
:: Mounting Points *C/C: 100mm x 140mm
:: Mounting Depth: 50mm
:: Magnet Diameter: 80mm
:: Required clearance above mounting surface: 0mm
:: Speaker weight (each): 596grams
:: Speaker Covers: Yes
2000Hz seems very low for this Mid-Bass Driver
Where would i cross the frequency if i wanted to add a tweeter?
