Sowter transformer 8347 I/V stage fot TDA1543
so im in this situation as well.
i've found just this, designer of my russian TDA1543 DAC suggests connecting through 10uf cap, like pictured. it looks like big caps are needed. what i dont understand is all those connected-together wires on the right side..
thanks for opinions
misok
EDIT - i overlooked this thread is about different Sowter model, i have 4383
I am using 8 pcs of TDA1543 . . .
With eight x TDA1543, you don't need a transformer - Google DDDAC and see Doede's write-up on the circuit which, though it only has only a resistor as I/V stage, works pretty well.
will the TDA1543 work with a DC short on its output?
Not for long.
