Hi
Do you know a source for "cheap" electrolytic capacitors, >=10000uF 80V ?
(So far the chepeast I found is 8.353 Euro + VAT, www.profusionplc.com)
regards
/Freddie
regards
/Freddie
Hi, there is a supplier in the US that sells thro' ebay doing very good prices on larger quantities. I did not bid just went straight to buy it now - much cheaper than UK. Service was excellent
I got 1.3million uF at 63v to 80v including 150,000uF Hi frequency for under 200gbp
regards Andrew T.
regards Andrew T.
http://www.neuhold-elektronik.at/catshop/product_info.php?products_id=249
10000uF/80V 2,9 EUR each (2,6 EUR each in quantities above 5). These are Nichicon LQ-series caps, IIRC farnell has the datasheet (do a search for LQ on their website)
/U.
EDIT: Andrew might be referring to this link: http://stores.ebay.com/JEA-Capacitors
/U.
