I have been looking for some 3W 0.33ohm 1% metalfilm resistors to use as source resistors, but I have not found any good sources.
I have been looking for some Vishay dale CPF3, but I have not found any sources with the 0.33 ohm. I have also looked for other brands, but most are not metalfilm or 1% resistors which I would prefer. If someone have a good source for some nice 3W 0.33ohm 1% metalfilm resistors I would be very happy and I am not looking for really expensive resistors like caddock or similar brands.
Please advice and please don´t turn this into a war of which brand is the best.
Martin
Martin
Michael Percy carries Roederstein and Holco or PRP; you might want to consider paralleling 3 1W 1 ohm resistors, much easier to find. Space them to allow air flow between them to preserve the wattage rating. This also has the advantage of reducing the inductance to 1/3 if they're spaced a bit.
just as Curmudgeon suggested you might wanna go with 3 in parallell. Here is a suggestion for you that should be easy to buy from.
http://www.elfa.se/elfa-bin/setpage...elfa-bin/dyndok.pl?lang=dk&vat=0&dok=7492.htm
I have looked at that resistor but it looks like they are not selling it in 0.33 ohm. The solution could as you both have said just buy 1 ohm 1 watt and then parallell three.
I have just found another solution at mouser, which could be the vishay Dale rs2b which can be found in 3W 0.33 ohm 1%.
Martin
Martin
