This amp goes to protect mode...i dont know what is the source of the protection but previously it was Intermiitent. Kindly give your usual help....
Pin 1 of the tl494 is higher than pin 2(6v, 2.5v respectively) i dont know who is givIng that high voltage. Thank you
Solder a bridge between pins 2 and 3 of each of the audio driver ICs (the ones with the heatsinks). Does the amp still go into protection?
Yes it still goes to protect...
Is there any DC voltage present on the output filter inductors at any time?
No voltage presents at any time.
Post a photo of the power supply driver board.
Hi perry, here are the photo. Thank you Perry
For the LM293 on the back of the PS board, which pin is high, pin 1 or pin 7?
If you cannot get to pin 7, I think the anode of D37 is connected to it.
Pin 1 and pin 3, i short the pin 3 to pin 4, protect disappear and powerup,but the amp is muted even before we put standby he audio driver.
That doesn't answer my question.
Sorry. pin 1 is higher. 6.8 vs 0.115
What's the DC voltage on pins 2 and 3?
2.5v and 4.7v
- General Interest
- Car Audio
- Soundstream taramps 2000watts
