For Sale Soundaware D100Pro Network Player/Renderer
Things you have for sale.
This is a terrific network player with excellent sound quality.
It is the Pro Version without external clock inputs. It is an FPGA based player and has the last firmware update installed (v 2.9.17) but this is now a few years old.
Bought this new direct from China quite a few years ago and used it extensively until upgrading to an alternative DIY player a couple of years ago. Physical condition I would describe as excellent and it is in full working order.
Comes complete with the original remote control, but is best controlled by a UPNp DLNA player such as Bubble UPNp.
I replaced the PSU electrolytic capacitors with quality Wurth brand about 4 years ago, so should be good for quite a while (see internal photo).
Can play music from NAS (10/100Mbps), USB stick up to 128Gb, or SD Card up to 128Gb (best in my opinion), in FLAC, WAV, CUE, APE (48khz), MP3.
Please Note - It does not play DSD natively. Upgraded FPGA firmware was promised to enable this but has not materialised.
Outputs as follows;
RCA coaxial: 0.5V p-p, 24bit 192 KHz
BNC (75 ohm) coaxial: 0.5V p-p, 24bit, 192 KHz
AES (110 ohm) coaxial: 5V 24bits, 192KHz
Optical fiber: 24bit, 96 KHz
It is 220/230v operation only, the mains selector switch on the rear is not connected, this is how it was supplied.
I have the original box for transport.
UK based, price is 200GBP
Also on eBay https://www.ebay.co.uk/itm/116117804532
