Sound Digital 8K
Dont know if its normal in this amp But theese diodes read shorted when in the board:0.0006 but test fine when out of circuit
I dont get any gate signals since the amp wont even power up.
I tested the outputs for leakage and they all test fine.
I removed the rectifiers and still the same thing they test shorted. (diodes)
Amp draws no current at all all i get is a blinking led.
I had the Outputs out of the amp when i pulled the IC's
Im gueessing the IC (2010) in the power supply is defective.
Im also gonna replace the transistors in the supply the legs arent looking the greatest and may break soon.
The drivers are KSP92 IS that that same as a MPSA92 ?
The other transistors are marked C33725 W 7d
Do you have a good part number for thoose?
Talked to them and he told me to send it to him for repair he wont give me any info on the amp
NO legs are fine on the new fets . The legs are ready to break on the small transistors.
I never replaced the IC as of yet. Guess i should have.
Im gonna put in a parts order right now Just need to know a couple things
The KSP92 transistor is that the same as MPSA92 ?
Also the diodes that read shorted say PH 1N 4148 so are thoose just the regular 1n4148's ?
