To confirm that you have the scope set correctly, check for signal directly on the terminals of the RCA jacks. Do you have signal there?
See if there's a broken wire/connection between the main and crossover boards. See if you can find regulated voltage on the main board on the pins of the connector that connects the two boards. Then see if it goes through to the crossover board.
- General Interest
- Car Audio
- Sony XM-1004gx
