Cheers for that lightning response
After a bit more googling, managed to find the 1670's at Cricklewood electronics - they've got the 4385's listed but no stock..... I've contacted them so hopefully they've got some under a layer of dust on a shelf, or can recommend a decent replacement.
I'll keep you posted And cheers again! Now back to trying to sort the right channel dropping out on my Technics SU-VZ220....
Sorted! Many thanks for the help
Had a word with Cricklewood Electronics, and after comparing datasheets, found decent replacements for the output transistors. Tested the driver transistors on the main board (all ok - if they're not, replace them), and replaced the output transistors with ones from Cricklewood:
In Sony TA-F110: Cricklewood Replacements:
2SA1670 2SA1673
2SC4385 2SC4388
All for under 15 quid
2SA1670 2SA1673
2SC4385 2SC4388
