Sonus Faber Electra Amator DIY?
Hello everybody!!:)
I wanted to make the electra amator loudspeakers, by Sonus Faber..
Is anybody have the original designs for the wood enclosure & the crossover circuits?
I would like to build a clone from wood ;) !
I don't know if i can make it but i'll give it a try!!!:smash:
Thanx a lot!!!:D
Thanx Ap!
I found in the forum the crossover, i'll search Stereophile for the enclosure..
Any other sugestion for DIY project in this kind of speakers?
My uncle a lot of years ago had bult the BBC LS3/5A with KEF B110/T27!:)
They where preaty cool!!:eek:
I think that i want a little more responce down there...
Correct the original Electa Amator (Extrema?) used an Audio Technology Flex Unit woofer- most likely custom specs, he will make any drive to your spec. The second series used Scanspeak drivers. The original would be far more expensive to make, but the xover is probably going to be easier, whereas the series two would be cheaper although xover much harder - take your pick!
The cross - over :
