Solid state switching of signals
What would be the cleanest way to switch an AC signal path on and off using solid state?
The signal is only low, a few volts, and since it's a signal I can't really make do with diode voltage drops, which immediately points towards bias / trigger devices where the only drop is from their internal resistance.
I'd prefer not to have to use solid state relays since they're kind of expensive and I need lots of them, nore do I absolutely need their isolation potential.
For low power signal I (and many others) use this way (T14 and T15 in the attached circuit) ;)
There are other ways, but this is nice and clean :D
- By the way.... This is from the QUAD 34 preamp
HC4066 and similar cmos swiches are classically used for things like these. VHC4066 is tad better in on-resistance and maxim-ic for example has improved versions that are still pin compatible with 4066. 4066 on-resistance is variable and varying with signal strengt, somewhere between 50-500ohms so your input impedance after switch has to be enough high.
